goosemasterkl
- May 2, 2014
- 54
- 121
I'm having a problem trying to find out what is causing my friends Cub Cadet 1517 PTO clutch from kicking off. I've put a new Pto switch on it thinking maybe that was the problem but no luck. I installed a new battery because someone was telling me a weak battery could cause this problem. Could the Pto clutch be bad even though it will engage whenever you pull out the Pto switch? If there is someone that could give me some advice on where or what to check I'd really appreciate it. Thanks
