cub cadet 1515 series pto switch wont engage blade
ricknmolly1
Started my cub cadet up for the first time since fall.pulled the pto switch to engage the blade and nothing.what's going on? It worked just fine last fall.
Check the fuses first, and then start looking for loose or corroded connections at the switch, and the clutch. Report back if nothing is found and we will come up with more suggestions.
