cub cadet 1042 wont crank
clueless
belt came off my cub cadet 1042 while mowing. drove it to shed & quit for the day. went out 2 days later.,put belt back on. mower will not crank. turns over fine. changed spark plug & fule filter no help.check plug for fire W test light, no fire to plug.can't find any reason why. mower about 4 yrs old only 30 or so hrs. was running fine when parked. any ideas about what's wrong
Ifixdit
Pull the valve cover off and see if the valves are properly adjusted.
