bryantsplace1
- Jul 4, 2015
- 7
- 15
I have a Cub Cadet 1022 and it has been running fine except for the last week or so. It started out as having to use the choke pulled out for a little bit and then about half way. Now it will not start at all unless you use starting fluid and then shuts down. I'm thinking the backfire device on carburetor is not opening up. Any help would be most appreciated.
