creepy issue with my hydro trans
j_cycles
Ive got a troybilt bronco 19hp kohler and hydro trans.was cutting with the bagger for the first time in a while and clogged up the chute. emptied it out and started to cut again but when i slowed down it would creep along (without pressing the pedal) any ideas?? its a fairly new mower a year or two.
Catherine
LawnWorld Support
Staff member
:shocked: Creepy! I'm going to move your thread over to our Troy-Bilt section to see if we can find you an answer.
Welcome to the forum! :welcome:
577jersey
The linkage needs a small adjustment,,there should be a linkage with a lock nut and threaded rod,,not sure how yours is set up but the rod needs to be made longer or shorter so the machine wont creep.
j_cycles
Thanks jersey i checked it a few days ago and the pivot plate for the linkage seems to be bent or off track.
Thanks again all
577jersey
Your welcome,,let us know how you make out:)
