Crankshaft Size
kh0432
How can I find the dimensions of the output shaft on a model 12S907-1411-B1? I have one in a Weed Eater One that I'm going to part out . Someone is interested in the motor but I don't want to pull it if it isn't the size he needs. He's looking for a 1" x 3" strait shaft with keyway.
Scrubcadet10
Moderator
Staff member
PTO Shaft Diameter 0.875, (which is a 7/8" diameter) PTO Shaft Length 1.813, PTO Threads 0.375-24 UNF
