Cranking problem
harper1
Have a Jofn Deere LT 155 mower that will not crank. We jumped the starter relay and it would crank, brought a new one and installed. Mower will still not crank, changing relay changed nothing. Anyone have a answer?
bakerg
Might need a little more explaination, but if you turn the key and it doesn't start, it could be 1 of the safety switches, under the seat, neutral switch, mower engage switch. Check these out or jumper them out to see if thats the problem.
Briana
Hello, I have moved your post to the John Deere Forum. You will have better luck finding assistance there. :wink:
Thanks for joining LawnMowerForum!!!
