crank case gasket
davidrouse
looking for some info on changing out crank case gasket. I have a 27hp vertical shaft briggs and I need to know if I need to remove the oil pump to remove the bottom side of the crank case? or if anybody knows where to find a service or repair guide. model # 44q777 0148 g5
