Greeting esteemed mower owners,
I have a 15 year old Craftsman tractor with a 17HP OHV Briggs and Stratton engine that won't start but occasionlly backfires. When I took it out of mothballs after a long winter the engine started right up and ran well. Then after mowing the lawn it started have a problem, it would crank and crank and didn't want to start even choked but eventually would fire up. Once warmed up it would run great. Then the other day I was running the tractor and engaged the mower blades and it stalled and would not start again. Here's what I've done so far:
1) Checked flywheel key and it's OK
2) Engine has spark
3) checked after-fire solonoid and it works
4) replaced spark plug
5) checked compression at 105PSI, not sure if this is a problem or not, have leak down tester on order to do proper test.
6) Replaced fuel filter
7) Adjusted valves, they were pretty much OK anyway.
8) engine will fire with starter fluid but quickly dies.
When it first happened I was leaning towards a broken key since it seemed that the problem occurred when I engaged the blades, but there's nothing wrong with it. I have gaskets on order to do a carb cleaning.
Am I missing anything?
Thanks
-Bob
2) Engine has spark
Thanks
-Bob
