craftsman trimmer rocker adjustment
natedawgk1972
i bought a craftsman 30cc 4 stroke trimmer today. Manual states that you must check rocker tolerance after 10 hours. I can't find the spec or procedure anywhere on net. its model 316731970 and from what I can see it's an MTD engine that is used in many trimmers. spec would be great - procedure would be better
.003-.006 at TDC compression for both valves
