Came out to find my 17 yr old lawn tractor had gas in the oil and gas backing up into the air filter. It just drained the tank through the oil filler hole after I removed the Oil filler tube. Had tried to start it with a jump from my car assuming the battery was weak when it wouldn't start. Think the block is cracked? or is there some other way gas would be all over the joint? This baby has been well used and pretty well cared for. She might be ready for the heep but If its something I can fix or if I can find a reasonably priced replacement engine I like to know. Craftsman tractor 15 HP built in 1995. appreciate any help
