I suppose you have tried rocking it back & forth while trying it?I have a craftsman t110 maunal transmission and it is stuck in reverse. the shifter will not move out of reverse.
I figured you did, because that's probably how you have to do it when it works right. Next step is to follow all linkage to make sure it's not binding somehow.I have.
