- May 6, 2010
- 12,007
I have had a grease gun put enough pressure inside of the spindle housing that it sideloaded the bearings to the point that the shaft couldn't be turned. More than once I have had the internal pressure of spindles be high enough that is opened the 10,000 psi bypass in my Dewalt grease gun. And that will crush the internal seals on sealed bearings inside of the spindle cavity.The grease may indeed make its way past the rubber seals from grease being pumped into the spindle. But rest assured: The inside of the spindle is not seeing 8,000 psi that a grease gun may be capable of producing against a dead end cavity. The bearings would push out long before that, and if not, the spindle housings would explode.![]()
