Craftsman push mower - motor won't engage
cowsarequirrky
I have an old Craftsman push mower motor# 143 374082 SLR6321A
(Mower model# 917372110; Lot# S111986; Serial #026367)
The last time I pulled the cord it didn't engage the motor, the pull cord retracted fast. Upon taking the pulley housing off the motor, I found the 'dogs', a larger spring and washer that were off the pulley assembly. The small springs were in place that hold the dogs, so I was able to insert them back in place. The larger spring and washer must go on the outside of the assembly that holds the cap down for tension when the cord is pulled and the dogs open to engage the motor. As I hold the cap that allows the dogs to retract or open and pull the cord, the dogs work. So, the pulley works, the cord is only a couple years old and there is no obstruction, and the mechanism isn't damaged that holds the dogs to open and retract. Does anyone have a diagram of how the remaining spring and washer go on for the pulley assembly to work when I put this back on the mower?0507151047a.jpg0507151041.jpg0507151046.jpg0507151046a.jpg
The roll pin in the center is supposed to be flared at the top to hold the spring and the washer on. It looks like the flare is gone.
cowsarequirrky
There is a slight flare in the roll pin, and it's a bit misshapen.... more oval than round. What order does the washer and spring go on. Does the largest part of the spring sit on the 'cap'?
Last summer I replaced the fuel line and another part, so I've been able to figure out some repairs on my own without having to go to a repair shop.
I appreciate any help.
Largest part faces the pulley, with the small end under the washer.
