Hello everyone
I have a small problem here with a Craftsman Platinum Series 7.25 mower.
The problem is it won't start without starting fluid. I've been through the carb three times now. there is nothing in the carb it is spotless. I can pull my heart out it will not start as soon as I spray a tiny bit of starting fluid through the air filter it fires right up and then dies. I had the carb cartridge out of the carburetor it is spotless all the O-ring seem fine. All holes are clear , No fuel is leaking or anything like that. Can it just be a bad carburetor?
