Repairs Craftsman mower just clicks and whines
Ixeye
My craftsman ridng lawn mower was working great but then it got stuck in a hole so pushed it out while running to use reverse gear at the same time. It reversed fine and then the motor just died. Now it will not start and just clicks and then gives a little wheezing noise. Tested the battery and came back as bad so bought another one. Still just clicks and wheezes. What is the fix for this? Brent. Bccarey@bresnan.net
briggs
check to see if all connections are clean and tight sounds like a bad ground
NorthBama
check starter gear?
Ricksmowershop
Try and turn the motor over by hand, see if it turns over and how easy it is
