Walk behind Craftsman Model 550 - Very hard to start
carlb43
I have a model 550 push mower. Has carburetor primer problem that has evolved into a motor that is
hard start. By hard to start I mean that it pulls very hard and I cannot spin the motor fast enough to start.
It would not start at all. I determined that a small tap screw, I think, is missing from the carburetor. If I put my finger over the small opening and pushed the primer bulb I could get it started. I ran good but not great. I re-attached a spring to the part on the carburetor that goes to the governor. The engine started and ran very fast and I quickly shut it down. Now it is very hard to spin the engine, it won't start, with the pull cord.
If I take the plug out I can spin the engine. Does not seem to be frozen. The piston goes up and down ok. Not sure what the problem is.
Any ideas?
