Hello all, I hope you can help me as I'm at my wits end. I have the above listed mower with a B&S Platinum 7.0HP engine. Last used about a week and a half ago, ran fine except for a period of about 10 minutes where it refused to start up. Once it sat for a bit it would start and run fine. Tuesday of this week I went and tried to mow again, the mower started, ran for about a 30 seconds to a minute and then died. It did this repeatedly. I thought maybe it was the air filter so I cleaned it, took off the shrouds and cleaned the engine out, same thing. I then thought maybe the fuel was bad (although it ran fine on the same gas the week prior), so I replaced it. Same thing. To make it even odder, if you dump the fuel out and then start the mower, it runs fine until the tank is dry.
Anyone have any suggestions?
