Craftsman LT1000 42 deck rear anti sway bar
defiantadp
I was mowing and all of the sudden the deck belt comes shooting out the back of mower. has one break/cut with a little tear in the top where it must have stripped off. but while replacing the belt I notice the rear anti sway bar bracket just laying there on top of the deck with 2 breaks but still attached to the bar that connects to other side (RH) so I look around cant find where the bracket attaches to frame/chassis??? I found the parts and ordered already but still not seeing where they go other than the one pin to the bar but then I got new parts just setting there like the old broken ones were. anyone got any pics or diagrams where they go??? Model number 917 271910 if that helps.
It mounts under the left foot board. One bolt goes through the frame and the other goes through were the foot board connects to the fender. That is fairly common for that to get broken. Side loading and stress from getting bounced around causes it to break where the bolt holes are.
