Mrbill1
- Mar 4, 2019
- 9
- 22
I have an LT 2000 that wouldn't start. After further checking, I determined there was no voltage going to the coil. Also when I turned the ignition on the fuel solenoid did not click, so it also had no power. I began checking at the starter solenoid. Then I heard the fuel solenoid click. All of a sudden there was a loud explosion sound. It seemed to come from the engine. It could not have been a backfire as the engine was not spinning. I could not determine where it came from.
After the explosion sound, I again have no voltage on the output side of the starter solenoid. I have not yet determined if my solenoid is bad yet.
Does anyone have any ideas about the explosion sound?
