craftsman LT 1000 42 cut 6 speed
llb
when I start my mower it is really hard to put in any gear..turn mower off and it's easy to put in gear..why is this???
tybilly
if your pressing the clutch/brake all the way down,make sure tou have the correct size transmission belt,and its routed right and all your belt guides are there,sounds like when its running the belt isn't making a big enuff loop to allow the transmission pulley to stop turning.
