Craftsman Help - Carb side mounted Solenoid
Also if manufactured after 2012 will have a non vented fuel cap, but have a separate vent on top of the tank which can clog if fuel contaminated, also the low perm fuel line has a plastic liner inside which will separate from the outside wall and collapse. If you pinch the fuel line together the area of separation will feel soft and spongy.
