craftsman ez walk repair question
thomasojam
Need help repairing throttle assembly for self propelled craftsman walk behind mower. Mine came loose in the housing and I am not sure how to fix.
Ifixdit
Go to Sears.com and click on Parts Direct then enter your model number and look up the parts diagram. If you take a close look inside the plastic housing you should be able to see a wear pattern where the end of the cable was attached. Good luck.
thomasojam
Thanks for the reply. I will try that.
