Craftsman DYT 4000
jguzman
My Craftsman DYT 4000 dies when I engage the PTO, what could be the problem?
Does the mower also die if you release the brake pedal. If so, then most likely problem is with the seat switch, or the associated wiring. If it keeps running with pedal released, then try removing the deck belt, and then engage the pto and see if it keeps running. If it keeps running with the deck belt removed, then inspect all the pulleys and spindles for anything binding.
jguzman
Thanks for the info, frozen spindle seems to have been the problem.
