Craftsman DSL 3500 with 16.5hp
Opa Nick
Won’t start, keeps burning the 20 amp fuse?
Blowing the fuse would indicate a short. Does it blow the fuse when it is installed, or when the key is turned to run, or when key turned to start. That would give a hint to were in the system the problem could be.
Also will need the actual model number of the mower from under the seat as well as the model number info from the engine to determine further.
Opa Nick
𝑻𝒖𝒓𝒏𝒆𝒅 𝒐𝒖𝒕 𝒕𝒐 𝒃𝒆 𝒕𝒉𝒆 𝒉𝒆𝒂𝒅𝒍𝒊𝒈𝒉𝒕 𝒓𝒐𝒄𝒌𝒆𝒓 𝒔𝒔𝒘𝒊𝒕𝒄𝒉, 𝒄𝒄𝒐𝒓𝒓𝒐𝒔𝒊𝒐𝒏 𝒈𝒐𝒕 𝒊𝒕. 𝑹𝒆𝒑𝒍𝒂𝒄𝒆𝒅 🥸
