Price Check craftsman briggs and stratton 34 cc 4 stroke trimmer power head
hot pipe
  • / craftsman briggs and stratton 34 cc 4 stroke trimmer power head
looking to see what its worth runs great problem with it the previous owner ran it to the ground sorta speaking...what happen is the screw holding the clutch bell on came loose..the clutch bell then walked forward to the point the clutch shoes expanded to the point of messing up the front cover just behind the pull start pulley. no damage to the pulley. just the front cover.and of course 1 of the shoes melted in to the cover locking the engine. up..so finally removed the clutch assembly cleaned up some of the plastic were the clutch bell rotates..re assembled just to run the little B&S engine. also the shaft was cut off right after the throttle housing. so no shaft purchase a clutch and clutch bell for it..
