Secret Ingredient
- Nov 17, 2016
- 4
- 11
I received a used Craftsman wheeled trimmer that was partially disassembled. The prior owner was partway through replacing the drive belt. I've got it put back together but the cutting performance is poor. With the clutch engaged (pulled back to the handle) I am able to hold the front pulley in place with one hand and slide the belt with the other hand. This seems like inadequate belt tension. Having never seen it fully assembled I'm not sure if I have the clutch spring attached at the proper point, or perhaps the clutch cable needs adjusting, although I don't see anywhere to make the adjustment.
When the clutch is engaged the belt is still fairly wobbly and loose feeling.
If anyone knows how this should be arranged I'd appreciate it. Thanks.
