CraftsxMan
- Sep 6, 2013
- 1
- 3
hello i have a craftsman 5.5hp mulcher..it ran fine last season and did so this season until recently. It will run for a solid 20 minutes then just die out, when i re prime it,it starts and runs for 5 seconds. only until i re clean the carb itll run for 20 minutes and do the same thing over and over.
Things i have done to it:
-change spark plug
-clean carb 5 times
-empty out gas tank and clean
-use a new jerry can with fresh gas
-replace fuel line
-new air filter
When i clean the carb i use carb cleaner and take apart everything , even cleaned out with a needle the little fuel jets on that bolt.
my mower is this one
-change spark plug
-clean carb 5 times
-replace fuel line
-new air filter
