jimvt
- May 7, 2012
- 9
- 20
Bought this unit in July w/5 yr maint. pgm.
After 3 uses it wouldn't start.
Craftsman repair guy said problem was the "safety switch" on the right side behind the mulch kit.
The mulcher was apparently a bit loose thus the switch was not making contact with something thereby
killing the ignition.
He fixed and it worked fine.
Until yesterday!
I wanted to mulch leaves but it wouldn't start again.
Seems like the same problem.
I removed the mulcher, cleaned the area around the switch, put it back tightly, cleaned the plug (only 3 or 4 time use) and NO GO!
Is this a common problem with this unit?
Sears item# 071250000000. Model# 25000
Any help appreciated.
Until yesterday!
