Craftsman 26 Hp Kohler engine ys4500
CurtA
I was mowing last week and the engine started cutting out. I thought it was out of gas but apparently not. I can keep the engine running by pulling the choke but this does not work well with a warm engine. I suspect either the fuel filter or the electronic fuel switch I have read about that stops the flow of gas to the carburetor when the engine is off. Any thoughts or pointers in the right direction ?
de dee
it sounds like you got some bad gas,. drain the tank and put some fresh gas in it add some gas cleaner , and see if that fixes it,
