Craftsman 22" wheeled trimmer
trooper1954
Hi,
I have a craftsman wheeled trimmer model number 944.361064 with a B+S 6hp motor. The belt kept coming off so I took the mower apart and found that the bearing seems to have come out of the housing....see pic. My question is can I re-use this bearing and press it back in, or should I replace it with a new one? Is this a common problem?
Thanks
