New this forum and recently bought this mower used and have a question on braking. When I'm in forward or reverse and apply the brake the mower stops as it should, however when I release the brake the mower takes off from where the throttle and transmission lever where at before braking. Shouldn't the transmission return to the natural position whenever you brake? As it is now if I don't manually put the lever back to neutral when braking it will take off on me as soon as I let off the brake. I used to have a yardman mower with the the transmission lever at the fender as this mower has also and when I applied the brake the transmission lever automatically returned to neutral, shouldn't my craftsman mower operate the same way?
