Craftman 6.25 push mower
Michael AA
This mower would not start so I cleaned the fuel tank, rebuilt the carburator, new air filter and spark plug gap 0.30, also fresh gas and oil.
It starts and runs for 10 to 15 seconds and stops. I checked the carb float and it appears to be working properly. I'm stuck, any help will be Greatly appreciated!
scott47429
will it run with the choke on if so you still have a fuel problem either bad carb or still dirty or a air leak at the manifold
You may have cleaned the carb but did you make sure that both jets were clean? The one on the float bowl nut and the one on the side if the carb?
