Hey, so, I have a push mower that won't start. I've checked the spark. That seems to work fine when I pull the cord and it's grounded to the frame. I've emptied the gas tank of the old gas and sprayed it out with carb cleaner and then redrained. I've taken off the carb and disassembled it, followed by spraying any hole I could find with carb cleaner. It seemed pretty clean though. If I spray a little carb cleaner in the neck of the carb the mower will very briefly start. The carb seems to be getting gas, as loosening the nut holding on the carb bowl, after adding new gas, seems to cause gas to leak out. Does anyone have any ideas on what to check/what could be wrong?
