Courier
geogeranis
Simplicity "courier" zero turn rider 2016, 2 quick questions:
1. Mower manual states tire pressures should be 22 and 12 psi. TIRES sidewall state app. double those amounts. Which is more correct?
Note: manual does not specify model of zero turn mower, just Simplicity.
2. How many grease fitting are there. I have seen only two, on the front wheels. The manual and you tube suggest upwards of 18.
Who is right?
Thanks,
george
Tiger Small Engine
Who is right?
Thanks,
george
22 psi front and 12 psi rear sounds good. Visually look for grease zerks on spindles, front yoke, striping rollers, etc.
