connecting rod
seeker
can anyone tell me the correct posistion for D-series connecting rod, up with part number or down towards deck, thanks Ken :-=)
dwblue00
I'll try to help, but it prolly won't be much. I do know that the rod and piston should have been marked when being torn down. I would try to find a exploded view (lawnboys website) to see if there are any physical features on how the rod is supposed to be installed. I also know that the conn-rod also may also be offest to 1 side on the piston. I would look at them both very closely. I sorry if that doesn't help you much, but I hope it helps.
seeker
Thanks for the reply, did get info on how to download manual, fortunately it does show the correct way........Although two of my Lawnboy manuals do not :-O ...My bad, I do know about marking for reassembly, got side tracked and then youngster helped me organize :)......It's ok now though and thanks for the input...Ken,
