TootsGarage
- Jun 12, 2017
- 1
Hi, I'm new here to this forum. I'm working on a Briggs and Stratton 19hp 33R877-003-G1. There is a medium knock in the engine. I took the engine apart and found he valve cap had come off and made it down into the crank case and got chewed up. I repaired the parts that got damaged but the knock is still there. The only thing that I notice is the play in the connecting rod. Can somebody tell me if his is too much play. It moves about a mm side to side but not in any other direction. YouTube link enclosed of connecting rod.
https://youtu.be/D15sogeQkng
