- May 6, 2010
- 51
- 11,431
Was working on a small 1500 watt buffalo generator earlier today, and this highlights the inaccuracy of compression testing on compression release engines. Engine has been setting with stale fuel, so had to clean fuel system and carb to get it running. It now starts on the first pull.
Now for the test results. Leakdown test showed less than 10% leakage at TDC compression stroke but only has 5 psi on compression test.
We can also contrast that with a Briggs intek on I am also working on that has 60% leakdown with 130 psi compression. Engine was run with improperly installed air filter cover and is suffering from dirt ingestion damage and likes to fog the local mosquito population.
