jd I HAVE A F725 .PLASTIC CAM BROKE REBUILDING . WHAT IS THE CCA FOR A 20 HP OR RECOMENDED BATTERY.
S sja Forum Newbie Joined Apr 11, 2015 Threads 1 Messages 1 Apr 11, 2015 / COLD CRANKING AMPS BATTERY SIZE #1 jd I HAVE A F725 .PLASTIC CAM BROKE REBUILDING . WHAT IS THE CCA FOR A 20 HP OR RECOMENDED BATTERY.
M motoman Lawn Addict Joined Aug 11, 2011 Threads 67 Messages 2,582 Apr 11, 2015 / COLD CRANKING AMPS BATTERY SIZE #2 Don't know specific answer for your application, but the tractorette (Craftsman) size I get is about 280 if I recall. I use that size in my Nissan but it has to be charged frequently. Winter here is usually 30F, sometimes 10F.
R Rivets Lawn Royalty Joined Mar 11, 2012 Threads 61 Messages 15,621 Apr 11, 2015 / COLD CRANKING AMPS BATTERY SIZE #3 In our shop lawn tractors with a single cylinder engine get a battery with 300 CCA. If it is a twin cylinder engine we put in one with 340 CCA.
