Coil
Martin
Hi,
I have to by a new coil for my 504 lawnflite ,how uninversal are these. If it is the same size is it likely to work
Martin, the coil you need is based on the engine not the mower brand. You most likely a Briggs & Stratton single cylinder, so a coil from an engine of the same make of a similar size within 5 or so years of your engine will most likely work. I hope that help.
