I have a B&S 125cc engine model 08P50247F1 I am getting no spark, can anyone give me the ohm values I should expect when testing primary and secondary side of coil? Or can someone tell me where I can find these specs?
Don't know the specs but the cable on the handle you have to hold not be pulling the coil shut down far enough off the kill switch. Allowing a no spark issue.
I'm guessing here, but checking the coil windings for continuity is probably good enough.
That's why I wanted you to check the cable first to make sure it was working before taking cover off and unplugging the kill wire and checking for spark. Because if cables not working right won't fire. What I was getting at before taking it apart.
I have never seen that Briggs engine with an external throttle control. It is most commonly used on the $1.98 BB mowers.
