I've broken the clutch wire off at the clutch. Can it be removed or does the clutch have to be replaced too? If it can, can I remove it without removing the clutch?
Depends on how much of broken wire is exposed. If enough wire is exposed, remove enough insulation so you can solder wire & cover with electrical tape.
