2012 RZT-S Cadet..mower needs to warm up (10 minutes) before releasing the brake..otherwise engine dies..it's not a fuel or electrical issue..it seems to be like the trans oil needs to warm up then it runs fine? Runs perfect after that..how do I check trans fluid or whatever is causing this problem please
