clutch on murray 15hp 40 inch is not effective.
slab
This clutch/brake is not effective almost totally free movement of the pedal. Gear change and braking do not happen. Could somebody explain the adjustment method. Thanks
If you post the unit model number I would tell us the type of transmission you have. Then we should be able to help you.
