clutch adj.
bebuzz69
I have a rear engine snapper mdl. 265x cant find serial; number. I put a new engine on it and I want adjust the plate on the bottom of the engine to the friction wheel. what gear should it be in to adjust. or whatever. is there a manual I can get that will show it. I went to snapper web site but they want a serial number. thanks.
bebuzz69
update I got it half adjusted, I put on a new friction wheel and brought the disk down to touch the friction wheel in reverse, but when I run it it goes into every gear except reverse, the other onesw 12345 all go great, just no reverse.
cashman
If one of the older Snapper RER's, this clutch adjustment has worked best for me. Place the gear shift into 3rd gear. Loosen the drive plate collar that attaches to the engine crankshaft and with the clutch pedal fully depressed, adjust the drive plate collar and assembly to where you have approx. 3/16" clearance between the drive plate and the drive disc with the clutch pedal fully depressed in 3rd gear. If the drive plate doesn't move far enough to engage reverse, you may have a linkage that is binding or bent or the tilt plate that controls the movement of the center chaincase that the drive disc attaches to might have a wear issue. The tilt plate is attached near the bottom of the rear most frame member with plastic bushings and the tilt plate and/or the plastic bushings may be worn.
mechanic mark
Results I know this is not your rer model but clutch adjustment should be same, see pages 16 & 17 in operators manual.
