are there set screws or pins on the shaft
M marty r Forum Newbie Joined Nov 1, 2012 Threads 1 Messages 1 Nov 1, 2012 / cluch removel on dixonzeeter #1 are there set screws or pins on the shaft
C chance123 Well-Known Member Joined Aug 14, 2012 Threads 11 Messages 824 Nov 1, 2012 / cluch removel on dixonzeeter #2 I believe you only need an 11/16 socket to remove the main bolt. Then you need to remove the clutch retainer (is what keeps the whole clutch assy from rotating) It "should" just slip off the shaft.
