SpecializedMok
- Sep 10, 2011
- 1
- 2
Hello,
I have recently just purchased the Toro Super Recycler Superbagger and extremely happy with it. The other super recycler models have a washout port port whereas this model does not. In the manual it says to just stand behind the mower and spray water from the hose in front of the rear right wheel and let the mower and blades run. I tried that and let it run for approx 2 minutes and I don't find it will wash the clippings off the deck well. It seemed to sort of remove the clippings off 1 half of the deck only. How do you guys clean off your decks? I guess this is not as easy as the models with the washout port...
