Cleaning gas tanks
G
goatroper
Guest
What do most of you use to clean metal gas tanks that have had old fuel in them for some time? This is on the 5hp horizontal B/S engine.
Thanks for your reply,
Goat roper
I use about a pint of parts cleaner with a half dozen nuts and bolts. First plug the tank outlet, put the hardware in the tank, then the cleaner. Put the cap on and shake well, turning it in all directions. Dump out the clean into a container with a rag on top to filter the cleaner and catch the hardware. Pour the cleaner back in, with a little more fresh cleaner and shake it again. When you pour it out the second time and particles out gunk come out, repeat until it comes clean. Blow the inside out with an air gun and let dry for a day. Should be ready to go. Coffee filters work great as you can see debris easily.
G
goatroper
Guest
Thank you mechanic mark and Rivets for your quick replies. I'll have to try that.
Goatroper
