Cleaning Gas tank and lines
I was wondering if anyone has step by step instructions, or good tutorial videos etc so that I know what I'm doing when I attempt to clean my gas tank and lines?
Thanks for any help.
LawnBoy97
What machine are you cleaning?
When I had to clean my chipper gas tank 6hp B&S from sitting for a year or so I strapped it to my rear wheel on my rider,filled it half full with carb. cleaner and some old nuts &bolts jacked the rear end off ground and let run in 1st gear for a couple of hours and it cleaned it real nice:dance1:.Be sure you put something under the cap and any other holes in tank so not to leak cleaner.:thumbsup: as for lines I would just buy a new one.
A John Deere JE 75 walk behind self propelled mower, circia 1998 or something ;)
I looked at the machine and I realized that the fuel line is super easy to locate...so I will probably do what you said about just replacing it.
