Checkmate Striping kit for HRX217HYA
tastg82
I just purchased a Honda HRX216HYA to replace a very old HRR and am interested in adding a striping kit. Has anyone used or put on a CheckMate striper?
HRX
Yes, I have. You have to make sure you drill the holes in the exact place. It does an excellent job. If you do not need it all the time you can leave the 2 levers on and remove the wheels. I use ty raps to keep the levers up.
The nice thing it uses multi wheels. This helps when you need to make a turn. I
bgregg32
I just bought an HRX217HYA last week. I ordered the Checkmate striping kit. I'm having trouble removing the right rear wheel. The left rear came off with no issues. The right side won't budge at all...like there is a locking mechanism preventing it from coming off.
bogdaN
Far as I know both wheels are same.U might have rust so need good penetrating oil.
